Does that mean there will be an official announcement or are we going to have to keep hitting the retry button??
I have same problem in Brazil.
Particularly since the implementation has caused critical global scope problems for the most popular Community developed web services SmartApps (SmartTiles, SmartRules, SharpTools, and moreā¦).
its good it broke everything ill say. solution may come quicker
So appropriate! Patch it up, baby - Elvis
Iāve been discussing problems with my presence sensors and potential work arounds. All of the workarounds I was trying were failing because of the OAuth, so we got talking about that too.
Just recieved an email back from them this morning - the fix might be out pretty soon!
The OAuth fix is nearly ready! In fact I may be able to give you some good news later this afternoon, I will come back to you shortly.
Just tried a few seconds ago and IFTTT connected fine
Although saying that, it does appear to have trouble reading my sensors when I try to create a recipe
Same here. Can see devices on IFTTT but cant access when selecting receipe. Also no devices in sharptools and pebble app
Yeah, mine connects fine, but then displays > problem accessing switches
At least itās a step in the right direction
Did anyone else have a system fault at around 01:40 this morning (UK)?
Smartthings suddenly decided that both myself and my wife had left the house - triggering the alarm to arm - then when we obviously set it off my moving aroundā¦
They weāre going to deploy a hotfix this morning, not sure if thats what caused the blip.
Seems so close.
IFTTT sort of works but wonāt show a sensor in a recipe.
Tried to install SmartTiles, itās now showing my location in the ST OAuth drop down (which is a start!) but then comes up with āClient is not associated with a SmartApp in location āHomeāā
I understand each of those words, but literally canāt work out what itās trying to get at. A developers error message if ever there was one, so canāt suss if itās a SmartTiles issue or a OAuth issue !
Itās a SmartThings platform issue. Affecting many third-party integrations that were previously working in the US. (Including SmartTiles and SmartRules).
Basically they fixed one part of Oauth which then broke another part of account authorization. And pushed it out as a hot fix so everyone was affected.
The independent developers are aware of it, but thereās nothing they can do about it. The fix has to come from SmartThings itself.
OAuth, because Iām getting it on SharpTools.
Okie dokeā¦ Iāll sit tight then!
The fix seems to be up now. I can verify that its working in the US. Are you still seeing this issue in the UK?
Sadly still getting an error (UK)
