Hello, I have a rule (routine) that if a switch is on for 45 mins, turn it off and send a notification. If I remove the “notification”, parts it has the indicator to process locally. If I add a “cloud” required component, does the entire rule process in the cloud or only the bit that needs cloud services (notifications, I think in this case)?
Would it be better to simply create a second rule that triggers when the device turns off to send my notification? Then the primary rule will be “local” and the notification cloud only?
