I have a fairly large room that uses 2 different motion sensors to determine various automations. I know that in the past, you would typically use 1 trigger coupled with as many conditions as you would like. Is there a way to do this with the new Rule Engine? Prefer not to use a VS for this.
In the example pasted I think you have selected any condition is true. Surely you want all conditions to be true, ie no motions detected from BOTH mention sensors?
Thank you both for your answers. I definitely hit “When all conditions are met”, however, it never triggers the VS. I believe it’s because it’s two timed triggers that are driving the action. I know back in the webCoRE days you couldn’t have two “triggers” because, well, it wouldn’t work right. You could have 1 trigger and as many “conditions” as you liked.
I would have wrote this as “there was no motion for at least”…But this rules engines uses “stays” which is a timed trigger.
This would have been 1 Piston in webCoRE but for the most part, I have been able to recreate many of my home automations with the new rule engine. Just kinda stuck on this one.
I know I can create two more VS (1 for each) and have a rule for each that says if motion stays no motion for 30 minutes then turn on. Another rule for each that’s say if motion then turn off. That’s 4 rules and 2 additional VS.
Now the rule above would be strictly conditional. If VS motion 1 and VS motion 2 are “all” on then turn off Bedroom. Yikes! That’s a lot of “rules” just to use two motions.
Maybe I’m wrong but using 2 motion with stays hasn’t triggered the rule for me.
Have you tried recreating the routine or deleting 1 trigger, saving, then adding the trigger back?
I know it sounds strange but I had to do this for a couple routines that weren’t working correctly.
