In the Device Handler list/table, there is a sessions column. What does it mean if there is a blue-ish “button” there that says “Home”? I assume it’s referring to my location named Home as my hub is named “home hub”.
It means it is running in the IDE for the location that is named in the button. If this is an app that you installed on a device (and have set it up from there), you should remove the IDE instance by clicking the little ‘x’.
