Correct. And after logging in, it redirects to https://graph-na02-useast1.api.smartthings.com/
Hi All,
I was facing the same issue, when trying to install Echo Speaks, Echo Speaks - Actions and Echo Speaks - Zones smart apps.
I managed to install them by picking one at a time from the github Repo then I could get them installed.
I hope it works for you guys as well.
Cheers,
Edvaldo Castro
You have to install the main SmartApp first, then you can install the other two at the same time. I think it fails because we were installing all at the same time and the āchildrenā of the main app canāt be installed until the parent is installed first. The instructions should be updated to state that. Btw, I was installing the same Echo Speaks apps.
