I want to change Hub Offline Notification value. You see red boder message is the need to change.
Help me!
Install this piece of code as app in ide, then go to my apps and look for Hello Home and customize…Enjoy!
definition(
namespace: “Hello Home”,
author: “SmartThings”,
description: “Hi”,
category: “”,
iconUrl: “https://s3.amazonaws.com/smartapp-icons/Convenience/Cat-Convenience.png”,
iconX2Url: “https://s3.amazonaws.com/smartapp-icons/Convenience/Cat-Convenience@2x.png”,
iconX3Url: “https://s3.amazonaws.com/smartapp-icons/Convenience/Cat-Convenience@2x.png”)
Change Hub Offline Notification value to my message when ST hub active or inactive, Thanks
example: “Your SmartThings Hub at Hiệu Và ng PTN is offline. Check your internet connection” to "mystring other"
Thanks.
Oh, I misread what you were asking. Not easy to do Maybe someone has code for that.
Thanks u
Thanks u. Not at all
Change message when ST Hub is offline. help me.
Mean:
“You SmartThings Hub at… is offline. Check your internet connection.” chang to “Hub at … is offline. Check your internet or power!”
