I previously purchased a double switch 220V and 5 V outputs controlled separately. However, I couldn’t make it work as two switches. tried many different drivers found on this platform. Is there anybody to help me on this?
This device exit in my Zigbee Multi Switch and Child Mc driver.
Are you tried with this driver?
- id: "_TZ3000_2xlvlnez/TS011F"
deviceLabel: TS011F Two Outlet
manufacturer: _TZ3000_2xlvlnez
model: TS011F
deviceProfileName: two-outlet
Hi Mariano,
Thank you for your quick response. I saw one of your messages and tried it - I deleted and added the device and it worked.
Do you know how we can control the LEDs on these devices? It doesn’t seem possible to turn them on or off with Smartthings. The original apps show how to do it, but is it difficult to add these capabilities to these devices?
I have this device and an Aqara Zigbee Plug which has a blue light. I cannot control or set them to be turned off at night, at least.
In some Tuya devices it could be done, but it requires several changes in the driver that I am not going to do.
You can change the option in the Tuya app, uninstall the device without the delete data option and that settings will be saved on the device.
