ah. that’s because your scene isn’t changing away from 26. So you get an initial ‘change’ sent, but then it’s just resending the ‘26’ code. I haven’t hit that yet because I’m using a toggle switch (scenes 20 and 21).
Will have a think, unless anyone else has already solved this?
Tagging @anon36505037 (for Fibaro knowledge) and @ady624 - the issue @npalfrey has is that on any press the dimmer sends ‘Scene: 26’, so the first press works, but subsequent presses don’t register as a ‘change’ in Webcore, because it’s still 26. Off the top of my head, is there any way for either
a) webcore to listen for a resent Scene, or
b) the dimmer to ‘reset’ its scene value after a press?
If not, I’ve made a modified handler which exposes two virtual ‘buttons’ which webcore (or smartlighting) can then use as a trigger, but it’s not set up for a momentary switch at the moment.
I think there are filters in webCoRE to remove rapidly succeeding messages with the same value - while this can’t be removed (would be a major change that could lead to a lot of people having unexpected consequences) - it can surely be added as a piston option so that the filter can be disabled. Will look into it.
