HUE: How do you trigger different colors in difference cases?
Hi there. I can’t seem to get this to work. When Is set my hue bulbs to turn on, it does that correctly but only with the last color I had set for the bulb before it turned off. I can’t get it to change colors based on triggers. Is there a way to do this?
Did you ever find an answer to this mike? I’m having the same issue.
