Hue + Cree bulb + ST 2.0
I have the new SmartThings 2.0 hub, along with the new Hue 2.0 hub. I’m trying to add my Cree connected bulb to both, but no luck. Will it only connect to 1 device? Any advice?
(It is connected to the ST hub and works fine)
All ZigBee bulbs can only connect to one hub at a time. You can connect it to either hue or st and the connect st to hue and it will work but if you want hue to see it, then you have to connect via hue hub and then connect st to hue via smartapp.
I figured that was the case. Thanks for the quick reply!
