Continuing the discussion from Is Philips Hue the neglected one and TCP the favored one:
I asked this in the long related existing Hue Topic, but no response. Guess I’m impatient, but decided to spin off to own Topic now…
Zippy… May I ask you (or anybody) a question regarding the Hue (Connect) Service Manager SmartApp?
I don’t understand the purpose of the “def parse(...)
” method in the Service Manager. I thought “def parse()
” was only required and called in Device Handlers, not Service Manager SmartApps.
I’ve searched all the Hue SmartApp and Device Handler code, and I can’t find anything that calls this method:
//CHILD DEVICE METHODS
def parse(childDevice, description) {
def parsedEvent = parseEventMessage(description)
NB: The above chunk of code is in the original SmartThings authored Hue-Connect.groovy as well.
The purpose of the other methods defined in the Service Manager are obvious and clearly called from the child Devices in their Command methods (e.g., “def on(childDevice, transition = 4) {}
”). I just don’t see the purpose of the parse method here, or even that it is used anywhere.
Thanks…?
