This is an odd one. Two of my Hue bulbs have a slider in their device page for color temperature that goes from 0-100K instead of 2000-6500K. All my other Hue bulbs have the correct slider.
Anyone ever seen anything like this? If I choose the color wheel I can select the right color temp but it’s not nearly as easy as the slider.
There is now an issue with Lifx bulbs. The slider for temperature change is set to 1-100 so when I try to set it at higher kelvin value I get the following error in the IDE:
[device id here] 10:52:00 PM: error Bad setLevel result: [422] [error:kelvin is outside of range: 2500-9000]
[device id here] 10:52:00 PM: debug Executing ‘setColorTemperature’ to 95
and of course the lower Kelvins give me:
[device id here] 10:56:02 PM: error Bad setLevel result: [422] [error:kelvin is outside of range: 2500-9000]
[device id here] 10:56:01 PM: debug Executing ‘setColorTemperature’ to 10
I have have tried my own device type with the following code:
controlTile(“colorTempSliderControl”, “device.colorTemperature”, “slider”, height: 1, width: 6, inactiveLabel: false, range:"(2700…9000)") {
state “colorTemp”, action:“color temperature.setColorTemperature”
But it still only results in a slider that goes from 1-100… Can you have someone look at this @slagle? I can’t be the only lifx color 1000 user having this issue…
