I had a GE ZWave wall dimmer switch installed and was working fine. Later I added a Phillips Hue light and connected the Hue Bridge. This resulted in my ZWave wall dimmer switch working intermittently and then not at all. I unplugged the Hue bridge and then the switch started working perfectly again. I’m going to try getting a longer cat5e cable and moving the Hue bridge farther from the SmartThings hub.
Update
I moved the Hue Bridge about 15ft away from my wireless router and Samsung hub and I had no success. Then I moved my Samsung hub 15ft away from my router and Hue bridge and now everything is working perfectly. I hope this helpful to anyone with similar problems.
