i cannot re setup my hue bridge… i had to reset it as it would not update to the latest firmware… now i got it updated and working in the philps v2 app.
cannot remove the hue connect app , and it will not try to resync with the hub (ie i need to push the button again but it will ask me and i cannot remove it)
i get the following error in the logs
674be651-6a9a-4d11-90de-678091c2a191 7:27:55 PM: trace Bridge: 001788228D67 - Host: 192.168.11.161:80
674be651-6a9a-4d11-90de-678091c2a191 7:27:52 PM: trace Bridge: 001788228D67 - Host: 192.168.11.161:80
674be651-6a9a-4d11-90de-678091c2a191 7:27:49 PM: error groovy.lang.MissingMethodException: No signature of method: script1462218508370503095275$_lightsHandler_closure17.doCall() is applicable for argument types: (java.util.HashMap) values: [[error:[address:/lights, description:unauthorized user, …]]]
Possible solutions: doCall(java.lang.Object, java.lang.Object), call(), call([Ljava.lang.Object;), call(java.lang.Object), call(java.lang.Object, java.lang.Object), findAll() @ line 499
674be651-6a9a-4d11-90de-678091c2a191 7:27:49 PM: debug Adding bulbs to state!
4894c9f9-143b-4787-a773-39e4b513a6b3 7:27:49 PM: debug raw humidity = 45
when i try to delete from the ide… i get “there was an error uninstalling your smartapp”
