Hub V2 clock must be wrong?
I have a hub V2 in UK. Just realised that a smart lighting app switched a lamp off an hour earlier. Confirmed in the activity log on my iPhone as well.
How do you set the time in hub V2? Where is it synced from?
The time is picked up from your location.
Is it correct?
I think I’ve read in the past to open your location in edit mode and save it.
Might be worth a try.
My location is correct, but have done what you suggested, basically opened up the circle a bit, saves and clicked done.
Thanks I’ll check again tonight.
Well tried tonight and same after the re-saving of location.
Supposed to be 12:25am but switches at 11:25pm. This is confirmed also in the activity on the iOS ST app
Choose a location in a different time zone… somewhere in Europe. Save and let it stay for a few minutes. Then set it back to your current location and save. See if that resolves the issue. If not you should contact ST support.
