Hub v1 or v2 as zigbee repeater / range extender
#1
Hello,
I have hub v1 from SmartThings. Currently I have migrated to hub v2 though. Can I use hub v1 as zigbee repeater / range extender. If yes, then how.
Also can it be used as zwave repeater / range extender ?
Can hub v2 be used as zigbee and/or zwave range extender too?
(Jimmy) #2
A hub can not be used as a repeater for either zigbee or zwave. If you’re in the US, the Iris 3210 outlet will repeat both.
#3
thank you for quick reply. Iris 3210 is still not the most cost effective solution.
I do read that xbee can be used as zigbee repeater here. However the post is not clear and I am not sure how to use xbee as zigbee repeater. Is there a concise post about how to use xbee as zigbee repeater?
(Jimmy) #4
~$30 is a bargain for two repeaters. If you’re not willing to find the instructions and go through the setup of the xbee, then the price you pay covers the convenience.
