We’re excited to announce the release of Samsung SmartThings Hub firmware version 0.30.3. Once downloaded, your Hub will briefly go offline as it reboots and applies the update; most customers will experience less than one minute of downtime. We will update the status page when the release is complete.
Hub Target:
Samsung SmartThings Hub 2015 (Hub v2)
Samsung SmartThings Hub 2018 (Hub v3)
Release Date: 04 May 2020 ~ 05 May 2020 Note that this release may be spread over a few days, so you may not see your Hub update the first day of the release period. We will post on this thread once all users should have received the update.
Release Notes:
Features
Several system updates for stability and security improvements
Improved reliability and responsiveness of Sonos device discovery
Increased the number of Zigbee devices whose metrics and routes can be tracked
Will this include the Smartthings wifi? I noticed mine says Connect home in the IDE firmware. I thought that the Smarttings WIFI was a V3. Can you confirm this?
This release is specifically for the Hub v2 (2015) and Hub v3 (2018) models. SmartThings Connect Home and SmartThings Wifi hubs are getting closer to sharing the same major firmware version as the v2 and v3 hubs though.
Increased the number of Zigbee devices whose metrics and routes can be tracked.
More details on this please.
Also, is there a maximum number of Zigbee and Z Wave devices that can be added?
Any chance this will fix some bugs in automation and Smart Home Monitor? The last 2 days my typical morning Disarm based on motion routine has malfunctioned and the siren has been triggered when it shouldn’t have when a door was first opened.
This happened to me too this morning!!! The Siren went off and my lights entered ‘Brothel’ mode, although in the ST app SHM was showing Disarmed and no push notifications were sent saying the alarm went off - all very strange.
And again this evening… looks like the system is being set to Arm stay, being disarmed in the cloud but the local instance of SHM on the hub isn’t synced causing the siren to go and the lights to go red. What have Samsung fiddled around with this time…
My hub was updated minutes ago even the configuration was to DON’T Update Automatically … strange, isn’t it?
Also it changed the my hub name. Too bad as it could generate a big error.
@JDRoberts … I didn’t know… thanks!
So, I don’t approval but can’t do anything…its ok.
But the situation of change my Hub name is very invasive, isn’t it
Same thing here…disabled the alarm, came downstairs and as soon as I hit a motion detector the alarm, and lights came on, but SHM not reporting anything. Then for some reason the alarm and lights fired up about 8:00 this evening.
I am only on the Classic app, and yes I use SHM, but it was not armed in either case. For the incident this morning I had just disabled SHM and had gotten my disarmed message from Alexa (virtual switch). For the one around 8:00pm today SHM had not been activated since the disable this morning.
User with Classic and SHM for over 3 years, nothing very elaborate. About 50 devices, including virtual switches.
SHM not working here either. Alarm went off this morning, and when I tried to turn it off the SHM was not loading. Only using classic app. A few moments ago it also has a red dot (next to Smart Home Monitor) saying migration issue on my home screen and when I click it, it says loading.
