I got my Skybell couple days ago as well. At first it was awesome but then tried the motion sensor and it would take forever to start recording. So I went to webcore and made a piston that would start recording when my different motion sensor which then would make Skybell start recording. Now it works perfectly.
Trying to find out now if I can get it to record for more than 30 seconds.
Anyone else having hub issues with this firmware? Immediately after my hub updated its firmware at 10:40am this morning (which it reported as successful), my hub has been going into a disconnected state every 1min 5sec. It has no issues before that. I’ve already reset it, moved it to a different switch port, and replaced the ethernet cable. I don’t get any ping loss to the hub even while its reporting disconnected, and my internet connection is fine. I’ve already opened a ticket with support, but wondering if anyone else is having the same issue.
Ever since this update yesterday, my notifications have been crazy slow. Some times hours later. I tried hard resetting the hub, but that doesn’t seem to have helped.
It would be highly unlikely that this would be related to the Hub. If you aren’t seeing lag in device events, the lag wouldn’t be from the Hub. That is, if you are seeing events in the mobile app which should have generated a notification, the Hub can be removed from the equation. Notifications are generated cloud-side as the connection is roughly like this:
Devices < > Hub < > Cloud < > Mobile phone
If you contact support with specific notifications which are delayed, they can investigate.
After the update, the only two Zigbee devices (Samsung presence detector and Samsung Zigbee door switch) have been unavailable. I tried rebooting the hub and taking the battery out and putting back in of the devices. ??
I deleted all my automations and set them up again and it seems to be working now. I have it set to when it detects motion at the front door, to turn on the front porch light.
Only weird thing, the skybell LED stays white for a very long time after running the automation. Not a big deal really.
my Samsung cameras stopped working so I removed them to add them again
and it looks like i can’t add them back, no option in the Market anymore.
Are now only Arlo cameras compatible?
Same here, presence sensors stopped working reliably (×3), even with new batteries. Motion sensors (Phillips Hue and smartthings) stuck in either (active / inactive) state for days. New batteries, Hub Reboots have not resolved this!
My hub has been repeatedly going offline after this firmware upgrade. I do not know if the two are related however. Am I the only one? A power cycle restores everything.
For the first time ever my hub was offline for 3 hours, when I returned home it had 3 Blue LEDs on the front constant, power cycling brought it back online immediately.
One of my 4 Samsung cameras now remains in available … and the last few firmware updates have broken my window / door sensors as they randomly become un available … this was actually resolved for a while but it’s all back again …
