So if I have an existing simulated switch and just change it to a virtual switch it will then run locally? Or does it have to be a totally new one?
Changing will work fine, but you will have to make sure that the hub field is set as mentioned above.
Any plans to make momentary button tiles local? Just curious.
Hub updated ⊠all my 4 Virtual switches now show local execution
@Zach_Varberg - Does the Virtual Dimmer Switch support LiFX and/or Hue? Iâd love to be able to use SmartLighting to mirror multiple colored lights using a single virtual device to control them all.
I am aware of TrendSetter and I am currently doing it in Webcore however it is glitchy (quite likely due to my coding). I would imagine this to be a common thing for people to want to do when having multiple colored lights. Please consider adding native support if it isnât already there so it can be done withing SmartLighting and all âlocalâ for faster syncâd behavior.
The feature will work for any bulb. However, note that currently the mirror behavior will only follow on/off and dim status. Color and Color Temperature will not be mirrored, so it doesnât help with moving a whole group of lights to a given color. Using scenes is probably the best first party option right now if you want a group of bulbs to all go to a single color. But, as you mentioned there are a few community solutions available for that behavior.
Is the AEON Multisensor on the horizon for firmware updating?
@Zach_Varberg Not sure whatâs whatâs up with my hub after the firmware but my hub has been restarting every minute since the upgrade. Itâs hardwired into the lan and there wasnât a power drop at the house during the upgrade. Any suggestions?
Iâll take a look.
The Aeon unit is z-wave and SmartThings doesnât support over the air z-wave firmware updates
My update seems successful. My ct101 thermostats are much more responsive now. If I make a change at the thermostat the app updates instantaneously now. Before it was hit or miss if it would update. Assuming this has to do with the updated zwave protocol.
Is mirroring color a feature that will be added down the road?
Really great job Smartthings Engineers.
- In the past I could connect my Samsung washer with Smartthings and it worked very reliable
- Then it stopped working from one of the other day.
- I opened a ticket and was told a lot about my WiFi network, which were the ptoblem. No chance to reconnect.
- Back in January 2018 Smartthings fixed this issue (w/o touching my WiFi) with firmware version 20.16 and the note"Fix for discovery of some Samsung Digital Appliances"
- It worked like a charme and very reliable.
- With the firmware upgrade today (version 21.12) you broke it again. Wonderful job, now Iâm not able again to connect my lost connection.
What are you guys doing, is it not possible to work on the firmware w/o crashing something you fixed in the last release?
Now I will get more information about my WiFi if I open a ticket. And btw, why isnât it possible to check a box when I want to have this update.
I am very sorry and recognize that the appliances have certainly had their difficulties. For this issue, I believe there is a TLS issue but one of the embedded engineers can speak more to it.
Using virtual switch in place of simulated has improved device reaction hugely, im detecting zero lag from app to device, thank you everyone
Hi @Brad_ST, thanks for your prompt response. Can you please get me in touch with one applicable engineer? I really would like to work this out. I also opened a ticket for that yesterday.
In a lot of cases, instead of Simulated Switches, Iâve created âOn/Off Button Tilesâ. Can those be switched to the new 'Virtual Switch" for local control?
Also, I have many " 'Momentary Button Tiles". Any chance for them working too? (I doubt it as I donât think there was a local replacement launched, but Iâm asking anyway.)
Canât say iâve ever use the On/Off button tile handler. Switch it over to the new Virtual switch and see if it works. Can always switch back if it doesnât.
I converted one of my (10) âOn/Off Button Tilesâ and it seems to work OK. Looks a little different now, but functionally itâs the same - other than running local now.
BTW, the reason I have the âOn/Off Button Tilesâ is due to my use of the old SmartApp âVirtual Device Managerâ by âbkeiferâ (I think heâs no longer a member) to create my simulated switches. That app creates either âOn/Off Button Tilesâ or âMomentary Button Tilesâ as needed. I am now planning to start using âSwitch Maniaâ by @infofiend
Update: Iâve now converted all (10)âOn/Off Button Tilesâ and (2) Simulated Switches to âVirtual Switchesâ. They all seem OK. Thanks!
