You are quoting the wrong person, that quote is attributed to @Donnelloni not me.
doesnt the the multisensor 6 run locally now? using the Aeon multisensor DH works great for meā¦cant see any issues
I believe if you are using Hue B smart local processing doesnāt happen. I think you need to use the default smartApp and Device types.
No, but Iām not using the standard DH. Iām using a custom one to provide illuminance updates every minute. Maybe use of a custom DH is the issueā¦
I could be mistaken but if you use the custom DH, which I used as well, to set the parameters, then revert it back to the local DH, the parameters are all still set on the device but you now have local control.
In my case I use the Smart Lighting app to operate an office light based on the multisensor light and motion detection, locally.
Any update on your hubās firmware?
Thanks for your feedback. Iāve also changed whatās displayed by the sensor on my app home screen (illuminance), and have changed the colours displayed by the icon as illuminance changes. I think I would lose all of that if I reverted to the standard DH.
Dave
understood. Just remember none of that will matter if the internet goes out haha.
I guess this means faster reaction between motion being sensed in a place and the hue lights turning on?
Self reply! Blazing fast response between an open/close sensorā¦ not so fast with a motion sensorā¦ still investigatingā¦
Did you validate / verify that the Motion sensor is set to Local versus Cloud?
I got a lot of inconsistencies out of a smartapp since update.
Love logging shows request to send a URL responded as received, but the hub never end up sending it.
Anyone know what could be going on?
Thatās strange! I tried it with 3 devicesā¦ oneās a 1st gen multipurpose
smartthings open/close sensor, and then I have 2 fibaro motion sensors (the
eyeballs)ā¦
The ST sensor is in local mode and itās blazing fastā¦
The fibaroās are both in cloud mode and one is blazing fast using a Hue
light, while the other takes a little longerā¦ activating a zwave switch
thatās in local modeā¦
Ideas?
I donāt but others might.
Even before the latest firmware update every one of my hue bulbs were extremely responsive in my environment even being cloud. < 1 second response time between motion sensors to on off, so for me I have always been running quick. With the firmware update you can see the small response time improvement, but for me, mine were already āblazing fastā, now they are on a little extra steroids.
Just got the FW update on the hub earlier this eveningā¦
Later in the evening motion sensors arenāt responding, one Iris (Smartsense Motion Sensor DTH) and one GoControl (Zwave Motion Sensor DTH).
Any suggestions?
NVMā¦looks like whatever it was has self-healed. Just checked them again some time later and now they are responding as expected.
Thanks to everyone for taking the time to assist! I had already done all that, but I tried it again yesterday morning. It took 2 more attempts to finally get it working properly. Iām happy I got it working again, but Iām also concerned that it took 3 attempts to remedy.
I received the FW update.
I also noticed that all my Zigbee devices which include the Samsung branded devices, Osram Lightify bulbs show āLocalā as the execution location. Except for the Z-wave devices which include Monopriceās recessed door/window sensor and Centralite smart plugs report āCloudā.
My question to those familiar with the update is: a way to have the Z-wave devices report āLocalā, too?
BTW, only after setting the device type for Osram Lightify bulbs (the white tunable oneās explicitly) from āOSRAM RGBWā to āZigBee White Color Temperature Bulbā, did the execution location change from āCloudā to āLocalā.
thanks
If your device is RGBW orsam lamp you want to select ZigBee RGBW bulb rather than
they both run locally now but you wouldnāt get all the colour controls if you on the wrong one.
Unless itās on the list or runs on a DH in the list, it wonāt be able to run locally
My hub is Firmware Version 000.017.00012
Hardware Version hub v2, US customer Rev E
Isnāt this hub an update behind?
2 hub updates behind now
18.22 and the latest 19.17
but @Keo has you beat, he was on 16.x a fewdays ago
