The problem affected locally running devices connected to hubs running the beta firmware. If you tried to use Alexa to set the level on a locally running device Alexa would indicate it worked but the light wouldn’t change state and the status wouldn’t update in SmartThings. Other commands like on/off and set color/color temperature were not affected.
@tpmanley Can you look into why I’m not in the beta yet as well? Since I’m granted access to the beta firmware forum section, I would imagine maybe someone forgot to activate my account on the beta instruction / feedback website? Feel’s like some of us that applied recently for beta access are in limbo here.
I’m in now on centercode site, but yes, I’m still sitting on firmware 18.22, any chance you @tpmanley or @slagle can tell me when the push to my hub might happen for version 19.X?
The firmware updated a few minutes ago and I tested switches and thermostat, all working nothing broken, which is a good thing. Checked some automations, and they are also responding as they should. I will check the IDE next to check my device list. The major thing will be my LAN devices, which go offline once in awhile.
