Hub Firmware and Edge Driver Release Notes - 0.62.X
They really need to rush this fix out, it’s the first time I’ve really been appalled at an update.
62.14 arrived here sometime in last 24hrs. Nothing obviously different, as you’d expect. But hoping it maybe yields a more stable network. Time will tell
Yay, this fixed my third reality garage door sensor.
Five days later status update.
Since the update my Ikea thread devices have been stable, but it’s too soon to say as I find the battery powered devices have a tendency to go offline after about 10 days.
However I’ve had Nanoleaf matter over thread bulbs drop off
Line twice, both bulbs were close to multiple other routing devices so it’s not a case of being isolated on the edge of the network.
They are also bulbs that recently got the latest Nanoleaf firmware update which I’d hoped would increase their network stability :roll_eyes:
Not a single issue here with any of my devices since one of the first beta versions from July/August.
@Kianoosh_Karami
0.62.15 has been a problem.
I have had 5 g-type Samsung Smart plugs disconnect and need re-connecting.
I have had an Innr bulb disconnect.
I have had various thread devices going offline.
I have had several samsung multipurpose sensors going offline.
None of this has happened before except matter over thread devices going offline.
Someone internally will reach out to you, and we can go from there. Thanks for letting us know!
Today, we will begin rolling out 0.62.16 to the following Hubs (Samsung SmartThings Hub 2015 (Hub v2), Samsung SmartThings Hub 2018 (Hub v3), and Aeotec Smart Home Hub). This release fixes an issue where adding Z-Wave devices could occasionally fail on the latest iOS/Android apps.
I lost one of my Hub v3’s yesterday evening, last check-in lists 0.62.15, my other one is up on 0.62.16 now. The bad one is 400km away, so hoping there is something that can be done to get it up and running again without doing the rather long drive? It does grab an IP and responds to ping, but does not show any hint of coming online again.
I suggest installing a Wi-Fi plug (not linked to SmartThings) to power the unit; that way, if it runs into issues, you can turn it off remotely to reboot it. I do this for all the properties I own. It works very well for emergencies.
I already have an option to remotely power cycle the hub, but that did nothing to resolve the issue most likely triggered with yesterdays 0.62.16 roll out.
Also, if you have your hub on ethernet you can put a zigbee or thread outlet on your wifi access point (if its a different physical device to your router ) so you can reboot it remotely.
I have a wifi security camera which occasionally goes offline, so I do a scheduled reboot of it every Monday evening which seems to keep it more reliable
Anyone with a SmartThings Station, has yours updated to firmware 62.xx yet? I have 5 built-in appliance hubs and I know these firmwares updates usually don’t always get applied to them. But 2 out of my 5 hubs have gotten firmware 62.xx and they aren’t either of my 2 stations. My 2 stations normally update to the latest firmware before my other 3 hubs do. I’m just hoping we do get this firmware for the stations and was wondering if anyone else has noticed theirs update yet or not.
My 2 ST Stations are still on firmware 60.13. I am starting to wonder if Samsung had decided to stop pushing firmware updates for the Stations.
Thanks for letting me know. My TV and Soundbar both updated to 62.14, but both my Stations are still on 60.13 and my Fridge is on 60.14. I think they will eventually update, but with all the problems they have been having with this latest release it maybe delayed or skipped till next firmware, especially as the Built-In hubs have different variants of the firmware then the mainstream hubs do. Lets hope we do get it as my Stations are my main hubs with the others being secondary hubs and 62.xx give us Matter 1.6, which I can’t use unless I remove them as secondary hubs.
The 0.62.X series seems to have had a rough stretch with 62.13 getting pulled and then 62.14 stepping in for the crash. Appreciate the part about 62.16 targeting Z-Wave pairing on the latest apps, since that sort of intermittent failure is hard to pin down. Are Hub v2, v3, and the Aeotec models all getting 62.16 on the same schedule, or is there a staged rollout order within that list?
Posted above:
But it does not include the Aeotec Smart Home Hub 2 (which is the V4) as it does not have z-wave
