My zwave radio reset seems to have quieted down.
Right after the firmware update it kept happening, but it seems to have stopped.
There were also hub update messages.
They also seem to have quieted down.
Hi.
I received an email that I would be getting the new beta firmware release and would be notified by email. Iāve not heard anything since.
Just wondering if the beta release is ongoing and it will happen or if Iāve been missed.
Not that worried either way but just wondering.
Thanks.
has anybody been able to get the Iris devices to manually update? I click check now in the IDE, but nothing showing up in live logging. the only one that reset was one that fell off the network and had to be reset.
Yep, still ongoing. We took a break on releasing to take a look at some of the feedback, add in some diagnostic utilities as need to hunt down issues, etc. I expect we will be rolling out a new release to beta customers who got the previous release as well as beta members on 17.x still in the next few days after the holiday here in the US.
Are you using the InfluxDB app? Another hub on the beta list was frequently rebooting until the user removed all the devices from that app, effectively disabling it. If youāre using it can you try that and see if the reboots stop?
If you click Check Now and the Last Checked
time doesnāt update that either means the device couldnāt be reached at all or it was already in the middle of an update. Can you try temporarily moving the device(s) closer to the hub to see if that helps? Sometimes the device doesnāt have good enough connectivity to download the ~150K firmware update file successfully but normal operation is fine.
Thanks @tpmanley, that was exactly the problem! Once I removed InfluxDB, the resets have ceased.
The z-wave issues remain however. I sent a reboot command to the Hub, these are some of the error messages I see upon startup. I cannot get errors for device ā3Eā or ā07ā removed from my logs and canāt help but wonder if that is where the root cause lies. I suspect these two devices are two switches that I physically uninstalled before I had a chance to exclude them from the network, I no longer have these devices in my possession.
Here are instructions on how to remove ghost z-wave devices:
plug your hub back into the wall, the Poltergeist is gone ā¦
Not related to 18ā¦as I am still on 17. But the battery reporting has been deteriorated across the ST zwave universe. The Aeon handler throws errors. One of my locks, although has brand new batteries still shows 1% nothing works to refresh it. ā¦
@trotsky40 Thanks, that is the exact process I have followed in the past when Iāve encountered this issue. This time however itās not working. When I try to remove/force remove the device from the mobile app I get a message saying a device was removed, however it still remains in my device list (mobile app and ide). These are the events logged when I try to force remove the device from the mobile app.
I can of course go to the IDE and delete it thereā¦but during z-wave repairs the device ID reappears with error messages and Iām back to square one. Support has been unable to remove the devices completely, hoping someone on the beta team can take a closer look and investigate what is going with my account.
The last checked time updates properly, and there is a Firmware update started entry in the events for the device, but it never updates. Iām trying this with a contact sensor that is about 4 feet from the hub. Iāll email in the specifics.
Is the lock pairing bug supposed to be fixed in this firmware? Iām still seeing the 0000 MSR issue
zw:Fs type:4003 mfr:0000 prod:0000 model:0000 ver:43.37 zwv:2.64 lib:06 cc:85,73,72,98 sec:62,63,80,71,70,86,20
All of my Iris Contact and Motion sensors were automatically updated within 48 hours after the ST Hub Firmware update. I only had one reporting Motion during the update while SHM was Armed and my Alarm went off, but this also happened with a ST Motion sensor in the past.
I did not have to try a manual update so I could not say if itās working.
Canāt wait for this to hit the masses (go out of beta). I have the Halo smoke detector and have waited for the firmware updates since I canāt connect it to both the halo app and ST at the same time.
Anybody else seeing a sync issue with grouped devices ?
My situation 5 mixed zigbee light bulbs grouped together with a no load GE ZW switch. I open the cellar door & only 3 of the 5 lights come on, I reach over & see the switch is NOT showing as on. I toggle it on, nothing happens, toggle it off nothing happens. Walk over to control panel & it doesnāt show the lights as on. " Alexa turn on the cellar lights ā, pause while she thinks, āOkayā remaining lights come on.
Go downstairs do ā¦ Come back " up control.panel & GE switch still showing as off. Tap control panel & switch a few times and nothing happens. " Alexa turn off the cellar lightsāā¦ " Okay"ā¦ Nothing happens. Lather rinse repeat.
" Hey Google turn off the cellar lights" get all kinds of strange search results on watch. Repeat 2-3 time finallyā¦ All lights turn off, " Okay 6 lights turned off"
Walk into kitchen and only 1 of the 2 lights comes on, crap shoot as to which one.
Tap " fan lights" virtual switch to turn on the 4 Hue bulbs in ceiling fan, Might get all 4 on, might only get 1 or 2 to turn on.
For a nice change groups controlled timers not motion or contact are working fine.
Single lights controlled by motion or contact are all working fine.
Yeah itās supposed to be fixed.
Did you remove and re-add the lock with the beta and youāre getting that fingerprint again? If you could reproduce that and ping me right after Iāll pull the hub logs and look at whatās up.
Please hit us up at beta@smartthings.com with the details of what you tried and when (to the minute if you can) and what didnāt turn on/off so we can dig into it. I took a quick look already and none of the obvious issues Iāve seen before were jumping out at me so having the exact time and behavior will help a lot.
I have a very similar problem, though Iām only on the current firmware. Trying a zwave repair would completely crash my system. Tech support was unhelpful.
Yep itās working now FE599:
zw:Fs type:4003 mfr:003B prod:634B model:504C ver:43.37 zwv:2.64 lib:06 cc:85,73,72,98 sec:62,63,80,71,70,86,20
