Hi,
just yesterday I started to have a problem with hub not communicating with eurotronic air quality sensor and showing the sensor offline even though it was communicating properly the days before without any problems.
The sensor hasn’t moved a bit, the only change I made yesterday was move this sensor to a different room in the Smartthings app. The whole time LED on sensor is green, which to me indicates that its ON and working. Tried to press the button from behind, didn’t connect afterwards. Tried to unplug the sensor, still with no results. Tried to switch the sensor back to the different room in smartthings, didn’t work as well (I tried this just to make sure, to me it doesn’t make sence that would be the issue)
Hub is apperently trying to communicate with the sensor, the log writes down
1:05:38 PM: trace POLL [SensorMultilevelGet(reserved212: 0, scale: 0, sensorType: 1, reserved110: 0), SensorMultilevelGet(reserved212: 0, scale: 0, sensorType: 5, reserved110: 0), SensorMultilevelGet(reserved212: 0, scale: 0, sensorType: 11, reserved110: 0), SensorMultilevelGet(reserved212: 0, scale: 0, sensorType: 17, reserved110: 0), SensorMultilevelGet(reserved212: 0, scale: 1, sensorType: 39, reserved110: 0)]
what should be my next move?
