Cety
July 30, 2015, 4:16am
#1
Hi, can anyone tell me what’s wrong with my code?
I can’t receive any post json values on my server side using that method.
def params = [
uri: "http:// abc.com/abc.php",
body: [
home: [homeId: "c2350d41",
extraData: "SmartThings"
try {
httpPostJson(params) { resp ->
resp.headers.each {
log.debug "${it.name} : ${it.value}"
log.debug "response contentType: ${resp. contentType}"
} catch (e) {
log.debug "something went wrong: $e"
Are you sure it’s being triggered? What are you seeing in the ST logs when this is triggered? If it shows success, maybe try using postcatcher to see what it’s sending just in case somethings wrong with the php you are posting to
Tested your post with postCatcher and the results look good. So it’s likely that either it’s not triggering, or you have an issue with your PHP you are posting to
"home": {
"extraData": "SmartThings",
"homeId": "c2350d41"
Here’s the quick code I threw together to test your post. It’s triggered on switch change. You can use a virtual one in the simulator
/*Post Test
definition(
namespace: "tierneykev",
author: "tierneykev@gmail.com",
description: "Test PostJson to Post Catcher",
category: "My Apps",
iconUrl: "https://s3.amazonaws.com/smartapp-icons/Convenience/Cat-Convenience.png",
iconX2Url: "https://s3.amazonaws.com/smartapp-icons/Convenience/Cat-Convenience%402x.png"
preferences {
section("Monitor This Switch") {
input "theSwitch", "capability.switch", title: "Which switch?", multiple: false
section("Post to This URL") {
input "postCatcherID", "text", title: "postCatcher ID", required: true
def installed() {
log.debug "Installed with settings: ${settings}"
initialize()
def updated() {
log.debug "Updated with settings: ${settings}"
initialize()
def initialize() {
subscribe(theSwitch,"switch",poster)
def poster(evt){
def url = "http://postcatcher.in/catchers/${postCatcherID}"
def params = [
uri: url,
body: [
try {
resp.headers.each {
log.debug "Header ${it.name} : ${it.value}"
} catch (e) {
Cety
July 31, 2015, 3:57am
#4
Thanks Kevin.
It works now.
sainib
October 6, 2015, 11:29pm
#5
Hi @Cety ,
I am attempting to do something similar to what you have accomplished…but am unable to make it work. My code is slightly different with client_id and client_secret in the header…Also I am encountering a problem with content type defaulting to to “text/html” whether I specify that or not.
Cety
October 7, 2015, 4:11am
#6
Hi Sainib,
If your server end using php,
try to catch all the posted data from SmartApp by using this -> php://input
see what did you get
Alternatively you can use postcatcher recommended by kevintierney to catch all the posted data from SmartApp
sainib
October 7, 2015, 4:01pm
#7
Thanks @Cety …It was indeed a server side issue at our end. Again, thank you.
