How to use the SmartTag2 Button only in specify areas?
Hey! How can I configure that the SmartTag2 Button only works when I’m in a specific area? I use it to open the door of my garage. But it shouldn’t do that when I accidentally push it when I’m not at home. I’m not able to set it as a precondition. Any idea? Thanks!
Assuming you have a way of knowing you are at home, such as the mobile presence on your phone …
Rather than opening the garage door with the tag, turn on a real or virtual switch with it. Then use the switch turning on to trigger a Routine to open the garage door. You’ll have more flexibility with the conditions for that.
