How to Use an Open/Closed Sensor as a Leak Detector
Awesome!
Thanks for posting.
If you don’t want to wait 2-3 weeks for delivery, you can get 5 of these for six bucks with Amazon Prime…
Didn’t know that these exist! Pretty neat, Have you had good luck with them so far?
Just put it together today. Seems to work fine. Using on a your basic RFD Mailbox that is almost 100ft away w/o a problem. I use 15 of these as leak sensors.
Working ok. Sometimes it doesn’t report an open. There’s not enough room in the case to get the right angle. Could put the board and put it in a bigger case but I’m gonna try a mercury switch first.
I had switch in a shed that’s hard to reach so today I put a o/c sensor in a single gang box and connected a single pole switch to operate a smart bulb. Now I have a convenient switch near the door.
Does the builtin reed sensor work as separate sensor from the external input? Or do they work in parallel (either will trigger as one open/close sensor)?
I believe it’s an either or situation. It can’t do double duty.
I finally actually made one of these. lol
Very cool!
