THE PROBLEM
Beginning in mid 2020, some users reported that presence on iOS phones and tablets no longer worked reliably to trigger smartthings routines because the smartthings app wasn’t always open in the background. Typically as soon as they opened the smartthings app it would work again.
At the same time, if they were just using the phone’s presence in native Apple features, including HomeKit, presence worked fine. and sometimes ST presence would work fine for one person in a household but not another, even if they had the same model iPhone.
Hopefully eventually the two companies will get this straightened out and iOS presence will work universally in smartthings again, but in the meantime, if you want to, you can use a physical device which is visible to both HomeKit and smartthings as a proxy for presence.
Which device to use?
Personally, I like Meross devices and use a number of them. These are Wi-Fi and work well simultaneously with HomeKit and smartthings. They have good safety certifications. And they are relatively inexpensive.
You can just use one of their mini plugs for each person that you want to track. But I am particularly fond of their power strip for this purpose. You can get either a three socket or a four socket one, each socket independently controlled, so that lets you represent up to four people in the household from just one wall outlet. They also have USB charger slots which you can use even while using the sockets for presence. And if you turn the socket on when you are home and off when you’re away, that might even be useful with something plugged in, it just depends on your needs.
These are available in both the US and the UK.
Make sure it says HomeKit compatible: they have a slightly cheaper line that isn’t, but you need HomeKit for this project.
US VERSION
UK VERSION
Create automations in HomeKit to turn a socket on and off
Homekit Automation
If that works well, you’re on your way.
Now you can use that socket as a proxy for presence for that person
Since both HomeKit and SmartThings can recognize the Meross at the same time, you can just use the socket as a proxy for presence: if the socket is on, the person is home.
SmartThings routine
Virtual Presence Sensor
If you want to get fancier, you can create a virtual presence sensor and turn it on with an ST routine when the socket is on. This then allows you to use “member location“ in smartthings routines and to do things like say “if everyone is away.“
Here’s a community-created Edge driver for a virtual presence sensor.
[ST Edge] vEdge Creator: a virtual device generator for end users
That’s your choice, but for most people just the socket should be enough.
Other issues
All of this is just a method for letting you use the phone’s presence in ST without requiring the ST app to track presence since it doesn’t seem to be very good at it for some people.
If HomeKit presence isn’t reliable either, then that’s a different issue and would require a different solution.
