Make sure you install the devices as well not just the smartapp. Go under My Device Handlers and install the appropriate device as well.
Is there a way to read the tilt sensor battery? Right now the battery says 100% in the ST device, but I just got a myQ warning that the battery is low.
Yes, if you choose to create the garage door as a door lock in MyQ Lite, then you can ask Alexa the status of the garage door. You do this by choosing Advanced on the âselect which garage door/gate to useâ page.
It works well for me, and I can simply say âAlexa, lock/unlock the garage doorâ and secure it with a PIN code for the unlock command in the Alexa app.
When I reach the IFTTT applet creation step, all I see under the smartthings device selection drop down is âOptions Unavailable,â despite my virtual switch being selected as a linked device in the IFTTT service. Does anyone know why this might be?
I also received this error. I have saved and published the device handler. Iâm confused by your reply here. âInstall the devicesâ. Do you mean go into the ST App on my phone and install something?
Not sure if it matters, but I have the latest Gen3 Hub.
I ran into the same âdevices. java.langNullPointerExceptionâ problem. I have uninstalled then re-installed the device handler & smart app multiple times. But I still go the same result. This seems to be the last step to get it working. I did get the notification from IFTTT when my garage door is opne/close. But the device status always shows open, regardless the door is open or close.
When creating new device handler from Template, it asks for Protocol. Is z-wave the right one? Once I select z-wave, I need to enter Z-wave manufacturing ID, Product ID, Model ID, Device join name, Name space. Is there any guidance about how to fill these fileds?
Thanks for the suggestion. I delete the device handler and create a new one. But I am still getting the same error. Here is the debug log:
debug Error at line number unknown: java.lang.NullPointerException: Cannot get property âdeviceNetworkIdâ on null object
debug Error! physicalgraph.app.exception.UnknownDeviceTypeException: Device type âMyQ Garage Door Openerâ in namespace âbrbeairdâ not found.
Based on my limited knowledge, it appears to stop at line 652:
childDoor = addChildDevice(âbrbeairdâ, sensorTypeName, DNI, getHubID(), [ânameâ: doorName])
But not sure how to debug it further.
I change the device type to âMyQ Garage Door Openerâ then the âdevices.java.langNullPointerExceptionâ error is gone. Now I am seeing âMissing MyQ IDâ in connected devices in MyQ Lite app. Need further debugging.
@2ndLeaf, hereâs what my device looks like:
Name | DO NOT PRESS - Simulated Garage Door Switch and Sensor |
Label | DO NOT PRESS - Simulated Garage Door Switch and Sensor |
Type | Simulated Switch and Contact Sensor |
Version | Published |
Device Network Id | DONOTPRESS-Simulated1CarGarageDoorSwitchandSensor |
Status | ACTIVE |
I named my device handler âSimulated Switch and Contact Sensorâ when I created the device handler.
Thanks, BartschLabs. My mistake was I didnât install the Door opener handler from brbeaird. Once I did that, and follow your suggestion, everything works fine.
Ok, I got through the steps only to realize that SmartThing_myQ may not be compatible with the new App. Is that correct? Do I need a âclassicâ app for this to work?
Great instructions. It works perfect.
The only disappointment is that the lights are triggered at OPEN rather than OPENING. It would be great if they turned on when the door starts to open rather than completed opening (since they are my outside lights as well).
Has anyone found a workaround for this?
Did you get it to work in the new app?
HI, Thanks for putting this information out. I have a question, I load brbeaird MyQ into smartthings with a multipurpose sensor.
What does the IFTTT do to add functionality to bebeairdâs MyQ? Doesnt his monitor if the door is open or close if you use the multipurpose sensor?
and does this work in the new SmartThings App?
James
nope, still hope to get help on this.
Were you able to find a solution to this?
Yes, you need the classic app in order to have the functionality to add âMy Appsâ.
