i can’t see it anywhere in (https://graph.api.smartthings.com), not in my locaitons, my hubs…etc…
why is it showing on my app ?
I have the same issue.
Same issue here
I was able to delete it using the android application. I’ve just removed the virtual hub editing my ‘home’.
Thank you Pablo, i have IOS, can you provide the instructions on how you “edited” your home. I don’t see a way on the iPhone app to do that but it can be beneficial for other folks
Hi,
select devices and just click on the three vertical dots in the upper right corner. Click “Edit” and you will be able to remove the virtual hub from there.
https://www.samsung.com/global/galaxy/apps/smartthings/images/smartthings_section05_02_pc.jpg
