Not a programmer by any means. I’m using the following code as a virtual switch device handler for a web power switch v7.
The problem is that when the actual switch is changed the current state of this virtual one never changes. Is there something I can add to make it update that state or is this a limitation of a virtual switch?
- V Tile device-type for Digital Loggers Inc.
- Needed for Multi Switch with Virtual Tiles to create virtual switch tiles in ST for devices that have multiple “switch[x]”
attributes within them and have on[x], off[x], and cycle[x] commands for each.
Also has support for device-label inside the name when on or off and polling occurs
metadata {
definition (name: “vTile_DLI”, namespace: “Ledridge”, author: “Ledridge”) {
capability "Switch"
capability "relaySwitch"
capability "Polling"
capability “Refresh”
attribute "lastEvent", "string"
command "cycle"
preferences {
tiles {
standardTile(“switch”, “device.switch”, width: 2, height: 2, canChangeIcon: true, canChangeBackground: true) {
state “off”, label:’${name}’, action: “switch.on”, icon:“st.switches.switch.off”, backgroundColor: “#ffffff”, nextState: "turningOn"
state “on”, label:’${name}’, action: “switch.off”, icon:“st.switches.switch.on”, backgroundColor: “#44b621”, nextState: "turningOff"
state “turningOff”, label:’${name}’, action: “switch.on”, icon:“st.switches.switch.off”, backgroundColor: “#d0d0d0”, nextState: "off"
state “turningOn”, label:’${name}’, action: “switch.on”, icon:“st.switches.switch.on”, backgroundColor: “#d0d0d0”, nextState: "on"
state “cyclingOff”, label:“Turning Off”, icon:“st.switches.switch.off”, backgroundColor: “#d0d0d0”, nextState: "cyclingOn"
state “cyclingOn”, label:“Turning On”, icon:“st.switches.switch.on”, backgroundColor: “#d0d0d0”, nextState: “on”
standardTile("Cycle", "device.switch", width: 1, height: 2, canChangeIcon: true) {
state "default", action: "cycle", icon: "st.secondary.refresh-icon", backgroundColor: "#d0d0d0"
valueTile("lastEvent", "device.lastEvent", inactiveLabel: false, width: 3, height: 1, canChangeIcon: false, decoration:"flat") {
state "default", label: 'Last Event: ${currentValue}'}
main "switch"
details(["switch", "Cycle", "lastEvent"])
def parse(desc) {
def results = []
log.debug desc
if(desc==“updated”) { log.debug “Device $device.label has been UPDATED”; poll() }
def on() {
sendEvent([name: “switch”, value: “on”])
parent.OutletAction(this,“ON”)
sendEvent([name: “lastEvent”, value: “${df(now())}”])
log.debug “$device.label is On”
def off() {
sendEvent([name: “switch”, value: “off”])
parent.OutletAction(this,“OFF”)
sendEvent([name: “switch”, value: “$device.label”])
log.debug “$device.label is Off”
def cycle() {
log.debug "$device.label is Cycling"
parent.OutletAction(this,“CCL”)
sendEvent([name: "switch", value: "cyclingOff"])
pause(6000)
sendEvent([name: "switch", value: "cyclingOn"])
pause(5000)
sendEvent([name: "switch", value: "on"])
sendEvent([name: "lastEvent", value: "${df(now())}"])
//log.debug "$device.label is Off"
def poll() {
def current = device.currentValue(“switch”)
log.debug “Polling - $device.label is $current”
log.debug "This - $this"
def outletStatus = parent.OutletStatus(this)
log.debug "Polling - Status is $outletStatus"
def OutletName = parent.OutletName(this)
log.debug "Polling - Name is $OutletName"
if(!current || current=="off") { sendEvent(name:"switch", value:"$device.label", isStateChange:true, displayed:false) }
def pause(millis) {
def passed = 0
def now = new Date().time
log.debug “pausing… at Now: $now”
/* This loop is an impolite busywait. We need to be given a true sleep() method, please. */
while ( passed < millis ) {
passed = new Date().time - now
log.debug “… DONE pausing.”
def df(e) {
// * df(e) - Date Format “E”
// * Takes epoch time format and returns Date formatted in current timezone
def locale = getWeatherFeature(“geolookup”, zip);
def tz = TimeZone.getTimeZone(locale.location.tz_long);
def formatted
if(e) { formatted = new Date(e).format(“EEE, MMM d, ‘at’ hh:mm aaa”, tz); return formatted }
