Trying to get the security side of STHM setup and operational.
View Sensors shows which items it will use for Arm(Away) & Arm(Stay) which makes sense.
The challenge will be things like Ring Door Bell, which is used in Arm(Away) , I don’t need or want the Security system telling me of an Intruder just because Ring see’s the postman, or the Vibration sensor on the door detects someone knocking. That’s just two examples , sure there are many more.
So how do I control what STHM sensors are included or excluded and possibly what element of that sensor in the case of the door sensor with vibration, open/close/ temp etc
Along with this, when you have a contact sensor that you use for an automation to set the mode on or off, how can you give an entry/exit delay ?
