How to I act on a preference when it is multiple true?
I have a need for a preference in my smart app which will allow multiple selection.
I can’t figure out from the documentation how I am supposed to act on this once it is set.
If I create
input(name: “modes”, multiple: true, type: “enum”, title: “Make Mode buttons”, options: [“Cool”,“Dry”,“Heat”]), required: true
How do I code a check to see if “Cool” was selected ?
Will modes be a string with comma’s, an array, a list of some type ?
What is the result if you log.debug “$settings”?
Or log.debug modes
Etc. For a start anyway. You should be able to tell if the result is a Groovy List (essentially an array, of course), since printas will show square brackets, right??
If not shown as a List, then it’s likely a string, but you can check this by running string methods against it (instead of Collection / List operations…).
I wasn’t sure if debugging output would work because a list might format out as a,b,c
Anyway I found code in the new git repo ( much nicer to search…grep multiple:true ) LOVE IT !
it uses
if (modes.contains(“Heat”)) …
So I am trying that.
I’d still like to see the output of settings.
Of course log.debug converts everything to a string but the brackets and colons are indicative of Lists and Maps.
The implied “toString” of Java / Groovy objects is a great tool if the method uses consistent delimiters.
I presume “contains” is a List method though. I have too poor memory to know offhand if it does anything with a String.
It prints as follows
initialize: modes=[Dry, Cool],basename=Bedroom
unfortunately contains is a string method meaning the string contains substring.
So even with this code we don’t know if it is a string or a list
the debug output looks like a list
I have the code working with contains.
It’s a List… [ ]
contains is also a method of the Class “List”.
So you can do something like this.
modes.contains("cool")
This will return a boolean for whether or not the input “modes” contains “cool”
So in an if statement you could do this:
if(modes.contains("cool")){
    //do something of modes contains cool
else if (!modes.contains("cool")){
    //if modes does not contain cool
    //do something
Also, this may help some :slight_smile:
