if you are not able to get the model from seller or supplier, how you guys to get the Zigbee/Z-Wave Devices Manufacturer information and Model? I know CLI we can see the Manufacturer, but we not able to get the Model.
But if you want to do the integration, will need to insert the model in the fingerprint right?
I don’t have any Z-Wave devices to try but you can get the model for Zigbee if you ask for JSON or YAML output. Works for Edge and DTH.
"deviceId": "xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx",
"name": "one-button-battery",
"label": "Bla bla bla bla",
"deviceManufacturerCode": "eWeLink",
"manufacturerName": "SmartThingsCommunity",
"deviceModel": "WB01",
deviceId: xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx
label: Yakkity Yak
deviceManufacturerCode: SONOFF
manufacturerName: SmartThings
deviceModel: S26R2ZB
Hi @Steven_Lim
For Zigbee devices, by installing Zigbee Thing Mc you will be able to see the data of the device when paired.
For Zwave you can install Z-Wave Thing Mc or Z-Wave Device Config Mc
There are also other @ygerlovin driver, i think
Thank Mariano… also would like to let you know… currently I had tested with the Fibaro RGBW 2. your Driver is not working. The driver not able to get the Colour change… I had tested with others driver as well, but also the same… not working…
how to ask for the json or YAML output? using CLI? and what command?
–help will answer your questions.
You can also use the web-based utility API + from @TAustin . This give you access to your account details, including detailed device information. You can get to it just from a webpage, so some people may find it a little easier than setting up the CLI. So just another option.
It’s a nice format if you’re tired of looking at JSON.
@Mariano_Colmenarejo recently posted a screenshot from API + which is a good example:
