Hi Guys,
Is it possible to get current state of a device during eventHandler?
example code:
def eventHandler(evt) {
def battery = evt.device.currentState('battery')
log.debug "get battery current state '${battery}'"
Hi Guys,
example code:
Yes, but not like that.
subscribe(battery1, “capability.battery”, batteryEventHandler)
batteryEventHandler(evt){
log.debug “${evt.displayName} ${evt.name} ${evt.value}”
These values would be current as they triggered the handler
Yes, I know we can get battery value by using that.
but can we get Battery state during capability.contact?
example code
subscribe(contact, "capability.contact", eventHandler)
def temperature = evt.device.currentState('temperature')
log.debug "get temperature current state '${temperature}'"
As you can see below, the device’s Battery current state is 63%.
Since we know which device trigger the event, so I supposed we should be able to get that device’s current state as well right?
I got it
evt.device.currentState(“battery”).stringValue
actually I’m almost there, only left .stringValue
You can check if a device supports a given attribute using the hasAttribute() method.
Then you can get its string representation like you are, using the stringValue.
So you could do:
if (evt.device?.hasAttribute("battery")) {
def currentBatteryAsString = evt.device.currentState("battery").stringValue
Fair warning, I haven’t tested that, but I think it should work.
Yeah, I was just thinking what if the value is null.
Thanks Jim
