Hi. I am trying to make a device handler which will retrieve the battery percentage from a device and I wanted to know how to do this. My device sends a reports attribute, “battery percentage” to the Smartthings hub every few seconds, but I just need a way to get it showing on the app. I’d really appreciate any help to get this working.
You simply need a capability/tile/event management you can copy paste from any device implementation in the public smartthing GitHub like: https://github.com/philippeportesppo/SmartThingsPublic/blob/master/devicetypes/smartthings/arrival-sensor.src/arrival-sensor.groovy
Capability
capability “Battery” -
Tile
valueTile(“battery”, “device.battery”, decoration: “flat”, inactiveLabel: false) {state "battery", label:'${currentValue}% battery', unit:""
Message:
def parse(String description) { def results if (isBatteryMessage(description)) { results = parseBatteryMessage(description) } else: // your stuff } private Boolean isBatteryMessage(String description) { // "raw:36EF1C, dni:36EF, battery:1B, rssi:, lqi:" description ==~ /.*battery:.*rssi:.*lqi:.*/
private List parseBatteryMessage(String description) {
def results = [] def parts = description.split(',') parts.each { part -> part = part.trim() if (part.startsWith('battery:')) { def batteryResult = getBatteryResult(part, description) if (batteryResult) { results << batteryResult } } else if (part.startsWith('rssi:')) { def rssiResult = getRssiResult(part, description) if (rssiResult) { results << rssiResult } } else if (part.startsWith('lqi:')) { def lqiResult = getLqiResult(part, description) if (lqiResult) { results << lqiResult } } } results }
Hope it helps. Of course if you directly have the measure for the battery, you can simplify the isBatteryMessage and parseBatteryMessage, even suppress them…
