How to create a routine that will run Windfree air conditioner in max (fast) mode first, and then switch to ai auto mode
Hi all. I have a Windfree air conditioner, and even though manually putting the ac in Windfree is great and works as intended maintaining the room in a nice temperature (after it was cool), If I turn on the air conditioner remotely before arriving home, and set it to “auto” let say, at 24 celcius, when I arrive home about 15 minutes later, usually feels hot, since it changes from 24 to about 26 or 27 and Windfree. Is there a way to create a routing for the ac to first, run in max (fast) mode, and when it finishes to revert back to ai auto mode? I only see with routines you can select one or the other.
What mode does it go to after the max mode? Is there a way to create a Routine that triggers on that mode? If so, create a Routine to set the Auto mode based on that trigger.
