import time
import os
import datetime
from glob import glob
from pathlib import Path
import csv
from time import gmtime, strftime
file = “C:/Users/Rout.Bikram/Desktop/PYTHONCODESAMPLE/nyc_taxi_data.csv”
FILENAME =Path(‘C:/Users/Rout.Bikram/Desktop/PYTHONCODESAMPLE/nyc_taxi_data.csv’).stem
a = “”
b = “”
recordSeparator = “LF”
padding_size = 4
Code to pad spaces in recordSeparator string
rcrdSep = recordSeparator + " "*(padding_size - len(recordSeparator))
charSpaceEncode = “EBCDIC”
padding_size = 8
Code to pad spaces in a charSpaceEncode string
charSpcEncd = charSpaceEncode + " "*(padding_size - len(charSpaceEncode))
charSetEncoding = “277”
padding_size = 20
charSetEncd = charSetEncoding + " "*(padding_size - len(charSetEncoding))
header=""
padding_size = 15
headerDecl = header + " "*(padding_size - len(header))
timeZone = strftime("%z", gmtime())
padding_size = 6
tmZone = timeZone + " "*(padding_size - len(timeZone))
businessProductionDate = datetime.datetime.fromtimestamp(os.path.getctime(file)).strftime(’%y%y-%m-%d’)
padding_size = 10
businessPrdDate = businessProductionDate + " "*(padding_size - len(businessProductionDate))
creationDateTime = datetime.datetime.fromtimestamp(os.path.getctime(file))
DateTime = str(creationDateTime)
padding_size = 32
CreationDTTZ = DateTime + " "*(padding_size - len(DateTime))
generatedBy = “FOUNDRY”
padding_size = 50
generatedbySource = generatedBy + " "*(padding_size - len(generatedBy))
sourceCompany = “DNB”
padding_size = 50
srcCompany = sourceCompany + " "*(padding_size - len(sourceCompany))
routineNum = “1599”
padding_size = 20
projRoutineNum = routineNum + " "*(padding_size - len(routineNum))
schemaName = “SCHEMANAME”
padding_size = 30
schmName = schemaName + " "*(padding_size - len(schemaName))
sourceFileName = FILENAME
padding_size = 254
srcFileName = sourceFileName + " "*(padding_size - len(sourceFileName))
def insertChar(mystring, position, chartoinsert ):
mystring = mystring[:position] + chartoinsert + mystring[position:]
return mystring
SETTING THE HEADER FOR THE FILE
s1=insertChar(a,1, ‘0’)
s2 = insertChar(s1,2, ‘|’)
s3 = insertChar(s2,3,rcrdSep)
s4 = insertChar(s3,7, charSpcEncd)
s5 = insertChar(s4,15,charSetEncd)
s6 = insertChar(s5,35,headerDecl)
s7 = insertChar(s6,50,tmZone)
s8 = insertChar(s7,56, businessPrdDate)
s9 = insertChar(s8,66, CreationDTTZ)
s10 = insertChar(s9,98, generatedbySource)
s11 = insertChar(s10,148, srcCompany)
s12 = insertChar(s11,198, projRoutineNum)
s13 = insertChar(s12,218, schmName)
s14 = insertChar(s13,248, srcFileName)
s15 = insertChar(s14,502, ’ ')
Header = s15
print(Header)
SETTING THE FOOTER FOR THE FILE
fileNum = open(“C:/Users/Rout.Bikram/Desktop/PYTHONCODESAMPLE/nyc_taxi_data.csv”)
numline = len(fileNum.readlines()) -1
recordCount = str(numline)
padding_size = 15
recordCnt = recordCount + " "*(padding_size - len(recordCount))
s1=insertChar(b,1, ‘2’)
s3 = insertChar(s2,3, rcrdSep)
s6 = insertChar(s5,35,recordCnt)
Footer = s15
print(Footer)
file1=open(“C:/Users/Rout.Bikram/Desktop/PYTHONCODESAMPLE/nyc_taxi_data.csv”,“r”)
with open(“C:/Users/Rout.Bikram/Desktop/PYTHONCODESAMPLE/New.csv”, “w”) as file:
file.write(Header)
next(file1)
file.write(’\n’)
for line in file1:
file.write('1|' + line.replace(',', '|'))
file.write('\n')
file.write(Footer)
file1.close()
