Hi there
does any body tell me how to config the JN5168 Tx power
Hi there
The 5168 can be configured with the Zigbee Home Automation profile, which would make it compatible with most of the zigbee devices that can operate with SmartThings.
However, I’m not sure it could work with the SmartThings hub, which is itself a zigbee controller, unless you’re intending to use the 5168 to simulate various end devices for testing. In that case, stick with the Home Automation profile, and you should be fine.
Although the 5168 can be configured with the Zigbee Light Link (ZLL) profile, that won’t work directly with the SmartThings hub.
http://www.nxp.com/techzones/wireless-connectivity/home-automation.html
