I was thinking of getting aeon micros with Leviton double or triple toggle switches, just not sure how many I can actually fit in a 2 gang box as I have never actually seen one.
thanks
thanks
Not sure how big those switches are. Here are some pictures of the gen 2 dimmer micro switch. For comparison this is next to the GE switch. If you need any other angles let me know
Candidly, it will depend on how many circuits are present. I just tried to install one behind a switch in a 2-gang box. The box holds a 3-way switch and single pole switch, so 4 total Romex (12/2 and 12/3).
Wasn’t even close to fitting.
ya #12 will make it tighter. Was this the new G2 or the older one. The original is 3x3x1.2" in size while the new one is 2x2x0.7" (Pictured above).
2nd edition.
I ended up swapping it with GE switch in garage that I could not get unpaired during V2 migration. So it’s living in a single gang box with a single #14/2 circuit.
Worked out well.
