I have so many open/close sensors that I wanted to quickly distinguish the difference hence the icon change. I don’t have to read the discription I just look down the right at the icon, quick and dirty.
You can change customize the icon … of most device types. I suppose that’s not an option for open/close
(contact Sensors)… but that’s obviously the solution that should be implemented here.
The “Closure” for custom tile appearances is not an option because it is hard-coded.
But what’s up with “canChangeIcon
” flag on a devicetile like this?
That is the first thing I looked for when I wanted to change just the icon. The only choice was change the device type to use these icons.
Yah… SmartThings needs to enhance several basic device types to allow customization of the icons for each possible state. That way you can use a door icon, window icon, garage door icon, cupboard icon, mousetrap icon, etc, without requiring a full DTH just for the damn icons.
It is very frustrating as even with the open system and I just modified the device type it won’t run local. None of the code I added or should I say replaced needs to be run in the cloud. I prefer to have the alarm run local rather than depending on the cloud. So before I complete the setup for the two garage doors I need to either get ST to allow the change, which might happen with the new integration. Or spend extra money and by ST multiuse sensors. I hate to waste two perfectly good sensors and spend extra cash. But running local is a necessity. I can’t see why the ST device type can have the question “are you using on a garage door” If yes use the Garage Door icon if False the standard open/close icon. This question is part of the MultiSensor configuration, so it isn’t a big deal to add the question.
