How do I locate the PAN ID for my SmartThings Hub? I would like to link it to an ISY Zwave Zigbee Hub.
Thank you
Thank you
The PANID is under the zigbee information for your hub in the IDE.
Just sign into your account, choose my hubs, select the desired hub, and you’ll see PANID listed A couple of lines below the zigbee channel.
Thank you !!! Do you have any idea how to find it on a Wink Hub? If not I should probably just dump it
Thank you!
Found it but now I need a link key which ia a very long number. Any ideas?
