Ok so it looks like the terminal command is done thru Assistant+, right?
I am a visual person and need to see how someone else has it setup.
Would there be anyway for one of you to share a small example of what you have setup or if someone is willing to write a small tutorial, that would be fantastic.
Once you do that, you can open the page containing the endpoints in safari and hold down the desired action to copy the url for that action. Then paste the url after "curl -k -s ". Again, remember to make certain that the url calls https not http.
Hi there, first, wanted to thank you guys for an awesome tutorial, I was able to setup the voice commands via assistant+ and toggle with my devices, my question is, how do I get to toggle through my modes? it looks like I only have access to devices. Thanks in advance!
For each mode that you want to control, set up a virtual switch (momentary works best here). Then have your modes trigger based on the switches being turned on.
