How can I set this up... is Smart Lighting the right app?
Pantry door opens
Light comes on
Pantry door closes
Light goes off
OR
If Pantry does not close
Light goes out after 2 minutes.
How do I do this?
Open the smart lighting app and configure as follows:
Smart Lighting Rule
Which lights do you want to control: Pantry Lights
What do you want to do: Turn on
Select Trigger: Open/Close
Which open/close sensor: Pantry Door
Turn on when: Opened
Turn off when closed: yes
You can set a delay here if you want.
Nope, that only wants to turn the lights off when the door is closed. I need them to either turn off after 2 minutes, or turn off when EITHER door is closed or 2 minutes (in case the door is left open).
You can setup a 2nd rule to handle using the power allowance feature
10 characters
Just had knee operation today. Bare w/me and I’ll screen shot.[quote=“jgirvine, post:5, topic:47636, full:true”]
10 characters
[/quote]
I have the same need for my hallway closets which don’t have lighting…so I turn on my hallway lighting so I can see.
This is the 2nd rule…the 1st being your open close rule.
That did it… thanks
