How can I get text on two lines in a tile?
I tried the following
standardTile(“batteryReset”, “device.batteryStatus”, inactiveLabel: false, decoration: “flat”) {
state “default”, label: ‘Battery\nReset’, action: “batteryReset”
And I get this
state “default”, label: ‘Battery Reset’, action: “batteryReset”
Looks like this
“/n” ?, does that work?
Well, ummm… sort of…did you see my screen shot ? :smile:
Is this screenshot immediately after updating? Did you go back out and back in and double check it? I’ve noticed when I make ui type changes it doesn’t look right until I exit that device and go back in
No, exited app entirely and made sure it was closed. Launched and navigated into the page.
If I can find a reset icon I could just use that :smile:
But would still like to know how to write the text on two lines.
Try putting it in double quotes instead of single
:wink: @Ron
If that didn’t work try this… Hehehe!
http://www.w3schools.com/tags/tag_br.asp
@Ron, try this:
standardTile("batteryReset", "device.batteryStatus", inactiveLabel: false, decoration: "flat") { state "default", label:"Battery\nReset", action:"batteryReset" }
or just for fun:
standardTile("batteryReset", "device.batteryStatus", inactiveLabel: false, decoration: "flat") { state "default", label:'Battery\nReset', action:"batteryReset", icon:"st.secondary.refresh-icon" }
nope, sorry missed it in there…
I don’t see what you changed.
Nope, same result
Nope, you get a really tiny (quotes added for this post so it doesn’t break line :smile:
Battery’
'Reset
What the hell, man! :wink: /n/r
And darn! We are all in IT! :slight_smile:
No, can we stop guessing now :slight_smile: (killed my battery on my phone trying these)
I can use the refresh icon and just say “Battery” but I already have a “refresh” which acquires current status and I don’t want to have the same icon twice, too confusing.
Yes, but SmartThings takes a very special class of IT. You must work with zero documentation and nothing should EVER work as you might expect.
Figured it out! You are on Android! :slight_smile: It works on IOS!
Of course it works on IOS !
Yes Android
@smart @Ron, chalk up another Andriod/iOS different with ST. I’m on Android as well.
Sorry @Ron I couldn’t help. I’ll look through more of my code to see if I can find an example.
I copied and pasted your code and dropped it in the device type I’m working on now and here’s how it looks for me (on a galaxy s5)
Crazy, HTC One M7 Android 5.0.2
Some kind of phone specific issue ?
I notice yours still pushes the text to the bottom when you have newline.
anybody got an icon of a battery :smile:
Maybe try without the decoration:flat?
Here’s another device with it centered:
//Timer & Output (No Parent Element)
	valueTile("output", "device.output_percent") {
        state "default", label:'Output %\n ${currentValue}'
    valueTile("timer", "device.timercurr") {
        state "default", label:'Timer\n ${currentValue}'
@Ron, Try one more thing? I’m sure this is the code you need:
valueTile("batteryReset", "device.batteryStatus", inactiveLabel: false, decoration: "flat") { state "default", label: 'Battery\nReset', action: "batteryReset" }
Looks like this: (different text I tested with)
Without decoration: “flat” :
