Being new on connect home I would like to know how can i change WiFi channel? Currently is on channel 5 and is causing interferences and poor signal and speed
Log into your router and change the channel.
How can I log into and do the changes?
Connect Home is the router.
I don’t know, but is it under network settings? See the following instructions:
I seen but I don’t find the option for change WiFi Channel. Can I connect the settings via web? And what is the address of the connect home?
Would like to know this to. As far as I can see, there is no ability to change the channel under network settings.
