Honeywell z-wave thermostat
Has anyone created a device that gets access to the schedule setpoints that are in the thermostat so that ST can view and change the setpoints and other data in the thermostat?
@zuperman4ever, the command classes supported for these thermos do not support accessing schedule data, just pretty much just the basics:
http://www.pepper1.net/zwavedb/device/209
Honestly, I wouldn’t want to change those setting through ST anyway. I’d disable scheduling on the thermo itself, and instead use a SmartApp in ST to manage scheduling. That said, ST would have to be ultra reliable before I’d disable the thermo’s scheduling ability.
True, I was just seeing about being about to change and view the schedule that is in the thermostat. If not possible like you mentioned above, then I will not worry about it too much and continue doing what I have been doing.
