My previously bullet proof ST/AT/Honeywell integration is on the fritz. Apparently the dual mode tile is no longer available? What do those of you using the 9xxx series have showing in IDE for the handler?
Anyone else having trouble getting dual mode tiles for this in ActionTiles?
I did the same, removed it all and readded. Changed the DTH and ended up with seperate Heat and Cooling tiles as my best option. I have also noticed that adjusting one or the other will not push the other out of the deadband like it use to. Now I have to adjust both if I am up against the deadband.
