Hi Steve,
Thanks for your guidance, just finished setting it all up using IFTTT, bit of a lash up, as we say in the UK.
But, I can set cooling and heating to a number of set temps, even frigging it to a off setting, as there’s no schedule setup.
Perfect
Kevin
I’m glad you got it working in a manner that’s suitable. I’ve been using IFTTT and Honeywell together since 2015 with very few issues. If you need anything else just PM me.
I have found a smartapp that came with the ADTtools2. It is called “Humidity Control” and allows to use the built in humidity sensor from the RTH9585WF as a trigger.
Thank for sharing. That info will be helpful to those on the community that have an ADT/SmartThings hub and wish to make use of this parameter on their Honeywell T-stat.
No problem. I thought I’d mention it because we had previously talked about it.
