The homeseer switches are the only ones that I know that have triple tap.
The battery operated remotec is popular for control of smart bulbs. It has eight buttons, and each button can be single tap, double tap, or long hold. So that gives you 24 control options from a device that’s about the same size as a standard light switch. Obviously, it doesn’t control the load since it’s battery-operated, but it works well with smart bulbs.
More about this and various other button options, some wall mount, some handheld, in the buttons FAQ:
I’d like to know which buttons and remotes are currently supported or might be supported in the future. Ideally, I’d like to find something similar to the following: http://www.evolvecontrols.com/devices/control-devices/glass-series Though alternatively just a simple nice-looking button which actually works unlike this Aeon according to Amazon reviews: http://www.amazon.com/Touch-Panel-Button-Switch-AL-001/dp/B00GL6B4GG/ref=sr_1_3?s=hi&ie=UTF8&qid=1421468320&sr=1-3&keywords=aeon+button There is an Aeon Key Fob as well, but it doesn’t seem to be very durable or stylish: What else is available?
The Linear/gocontrol WT00Z1 is also popular for wireless control of smart bulbs if you want a mains-powered option. It’s intended as an auxiliary switch, so it doesn’t control the load, but it is wired to power. It’s a Z wave device so it sends a message to the hub which then sends a message to the smart bulbs. Noticeably less expensive than a master switch. However, it doesn’t do double tap.
https://www.amazon.com/Linear-Z-Wave-3-Way-Accessory-Switch/dp/B00EAY3K5Y
